Resetting soft and hard limits on Longer Ray 5 10w
I keep getting messages about hard limits and soft limits when I try to run a job. Is there a way to reset the limits on the laser to prevent it from telling me the design is out of bounds. It isn’t out of bounds on my lightburn screen.
If the firmware complains about limits triggered, that should have higher priority than your LB screen. If you set the starting positions incorrectly, LB will think everything is fine, whereas the laser crashes into the frame.
If you homed correctly and use absolute positioning, this shouldn’t happen. Check the preview window if your overscan is too high.
Apart from that, you can turn off hard and soft limits in firmware settings, $20 and $21 can be set to 0.
thank you very much
