I want to make houses about 1.5 inches. Can this be done in one swipe?
How big are they right now?
If drawn at 1", select all and lock aspect ratio then input 150 in the percent box next to the H size or the V size.
You can adjust the overall size as @JimNM suggests, but then you must adjust the slots & door hinges to match the actual (measured!) material thickness. The LB resizer may handle the holes, but I think you’re on your own for the hinges.
