I’m still having trouble cutting out what’s on the screen.
The image on the screen is both upside down and mirrored when I cut it out. This has happened when I have upgraded to newer settings.
Is there anything that can be done to revert to older settings
If you don’t know enough about your machine setup or are not sure and can check if it is correct after the update, I would go back to the last working version and look for these parameters and create a “Bundle” with all the data. The bundle can be easily imported into the new (all newer) version.
It sounds like your origin is misconfigured, if that’s the only thing you’re struggling with you can also quickly select the correct origin in your machine setup.
