Hi .Im brand new to the laser community. I have purchased my 60w mopa fibre laser and now have it all setup . It has autofocus which is one less thing to worry about. I purchased the laser to enable me to resurface golf club grooves and tidy up worn clubs. I also will look at logos and names in clubs so that I can personalise them . I’m hoping to be able to do deep enough to be able to add paint fill to these. Looking at the settings in lightburn as a beginner looks very daunting and need help with a start up settings to clean up grooves. I then can tweak them from there. Thanks Mike
I am pretty sure the club faces are cast aluminum. Find some scrap aluminum plate and practice on that to get a feel for the settings. Aluminum is an excellent heat sink, so expect to use lots of power.
Primarily made out of stainless steel and carbon steel
Haha! It is obvious I do not play golf!
You aren’t completely wrong, because some inexpensive kids clubs are made out of cast aluminum ![]()
Hello, Mike
I have a 60W MOPA with 100x100, 175X175, and 300x300 lenses. Been experimenting with all sorts of metals for 3 or 4 years. A couple things to get you started:
1.) 100% confirm the auto focus is calibrated. Half a mm will affect your results, 2mm you will think your laser quit working. Auto focus can be iffy. Have a way of confirming.
2.) Watch videos on timing and delay, get that dialed in.
3.) find some scrap or used clubs to practice on. Practice, practice, practice.
4.) Fab up a jig for repeatable accuracy.
5.) Post up lots of photos with your questions, and screenshots of your setup windows.
6.) Don’t expect perfect results first time around.
7.) Assume first time try will be a practice piece. A $3.00 chunk of steel will be a $3.00 practice piece. A $400.00 club will be a $400.00 practice piece. A $2500.00 watch will be a $2500.00 practice piece.
Have fun!
Thanks for the reply . With all the teething issues I’m having with usb drivers and autofocus out of calibration which has stopped my machine from engraving ,I’m finding my way around. I’m just struggling with import a photo and marking the area that I wish to resurface/engrave . The photo is a wedge face that I want to clean up the grooves and face . I can get the area marked out but struggling to resize it to get back onto my work area in lightburn. Even with the padlocked locked it seems to be either too big or too small . Can anyone direct me to a video that will help ? I’m just trying to cut the grooved area out and into lightburn Thanks Mike
Hello, Mike
Once I have the general shape I place the object under the laser, assure focus, and go to node edit, adjust a little bit, frame, adjust, frame, and repeat until I have the shape I am looking for. Then you could add the rectangles for the individual grooves. So it would benefit you to:
1.) Make sure the club is placed so the grooves are square with the laser, and
2.) Make sure your framing laser is matching your source laser.
You must take the photo perpendicular to the club face from far enough away to reduce perspective distortion.
Put a small digital level on the club face, snuggle the head in that bed of rice until it’s … level … along both X and Y, then take the picture from directly above. The camera in your phone should have a Framing Hints setting to enable the leveling cross to help you hold it both level and centered on the head.
Then do this:
- Accurately measure the longest groove = “real”
- Import the photo
- Use LB’s
Measuretool to measure the same groove = “image” - Select the image
- Lock the aspect ratio
- Use the
Numeric Editstoolbar to rescale the image by 100*real/image
That should get it closer to the goal.
