Hi. Is it possible to return to start position when I press the STOP button in Lightburn ? Or it only works after job is finished ? or maybe there is an option to set START point and END point of cutting on the object
Stop is treated as an emergency stop, so no movement is performed after you hit that button.
If you set a User Origin and use the User Origin as the start position it will always move there first, then run the job, and there is a button to go to that origin as well. You can also set the “Finish Position” which is where the laser will return when it has completed a job, if enabled.
