Hi everyone. Sincerely apologies. I have been doing engraving onto plywood and the name use for engraving is KatoriaLuke. However every time I engrave the result is reverse. However when I deliberately use “V” to reverse the name the cutting comes out to be normal "KatoriaLuke. I know there is a setting besides "V & “H” to correct it but I have forgotten how to do it. Can anyone advice the correct setting please. Thank you.
Your origin in Edit-Device Settings is likely incorrect. It should be bottom left for your laser.
Thank you for your quick advice. Yes you are right and it happened before where I got it fixed but this time I forgot after encountering this issue. Now its working well. Thank you again
