Very much new to the laser space but I’m looking to get a 60W galvo fiber laser to continuously cut aluminum. I would have the laser set up to continuously run, staying stationary while the roll moves, letting the laser cut the material, periodically moving up and down to account for a tab/ notch. Does Lightburn support this kind of implementation? Would I need additional components or would it be possible to just leave the laser on and adjusting the timing?
Can’t really answer your question very easily as you’re lacking information, such as the thickness of the material.
You’re attempting to move the X axes by moving the material, usually that’s the reason for the speed of a galvo, as you can’t possibly move your roller system anywhere near the speed of aa galvo.
If you move only one axes, the fiber would be still, only engraving at the same spot, with the a slight exception of the ‘tab’. That would only be using one of the two axes, which one of must control your motors to move the material.
Numerous sites claim to to things like cut aluminum. One site sets the machine to cw mode, then it takes ~60 passes to get through 0.30mm aluminum. Their machine is a 30W MOPA.
Ah gotcha; I should’ve clarified in my original post. The aluminum sheet I’m cutting is ultra-thin (20um); I’ve been able to successfully cut the sheet using a single pass.
The main issue I’m running into is if Lightburn is capable of doing the actions I want it to do. I was intending on having the laser stay put for a set amount of time before moving upwards, then moving back down to account for the tab. I did some digging in the manuals, and it looks like I could do repeat marking or split marking to copy paste the job over and over, but unfortunately the machine I want to install the laser setup into doesn’t have a way for me to connect its motors to register the X axis, and batch autofeed won’t work since it doesn’t have a Ruida or Trocen controller.
For additional context, what I’m doing is mainly a proof of concept; I don’t need to get too nitty gritty into precision, just trying to prove if something like this would work.
I’m going kind of the same direction as Jack, if the tabs are uniform I would make the “Art” a line with a tab at one end, and the length equal to center to center of tab spacing. As long as that was less then the field of the lens, you could easily roll, cut, roll, cut as many times as you wanted to set up. If the tabs were unevenly spaced or spaced greater then the working area it would still be workable but there would be a different procedure, you would need to draw the entire roll out and use slices.
You could even connect a microswitch or other sensor to I/O 14 or 15 to shut off the process at end of line.
I am working on a project that establishes 2 way communication between a BJJCZ galvo board and a grbl controller for similar projects but to do what you want LB and the laser alone could accomplish it with the rotary, split marking, or repeat marking settings.
So I just checked the machine this morning, and unfortunately the roller machine that I want to install this into doesn’t allow for a start/stop feature to allow me to do batch processes like Jack had mentioned, and I don’t think I can get into the rotary drivers to connect it to the laser machine. Which is unfortunate, since I think this would’ve been the significantly easier option.
Alternatively I was thinking about doing something where I thought about just creating a line in Lightburn that goes up and down, and is slightly angled to account for the movement of the sheet, then maybe use the repeat marking tool to have it continuously operate and repeat; this way I can still do cutting while the sheet moving at a constant speed. Definitely a lot more rudimentary, but might still get the job done; what do ya’ll think?
I think you’re making this rather complicated. If the roller on each side is gaining material or loosing material there is no way to compute how much material is actually moving. It acts much like a chuck rotary, in that the diameter if very important as it changes as you proceed.
As far as I know there is nothing in Lightburn that allows rotating based on anything other than the fixed diameter. Since yours isn’t fixed, I don’t know how you’d control it, I doubt Lightburn has this option for a variable diameter object. That leaves driving it with a wheel or something that actually know how much metal is going through it.
Makes sense yes. I think that’s the big challenge I will really be running into, since I will essentially be running the roller and the laser machine independently of each other with no communication; I would just start up the laser, then start the machine, and brute-force the timings until I am able to prove the concept. Ideally I would just use the feeder feature in Lightburn to do this, but the laser I’m going to use doesn’t have a Ruida or Trocen controller.
That being said, I’ll give Al’s method a try. If there isn’t a way that I could start/stop the roll, maybe I can do the shape without having account much for moving. Once I get going I’ll update here to see how it goes.
If anyone wants to chime in on additional methods, please feel free. Thanks so much to those who have helped so far!
In a past life, I was a PLC programmer for automation software. You need to write down all the variables and parts that need to be synchronized from the postings above.
Did this sound worse when you read it than when wrote it? I know you said, “is mainly a proof of concept” but hoping it will work is no proof.
Sculpfun has released a Flying Fiber Galvo option for some machines. And I think Lightburn mentioned having newly added the software control for such a system to Lightburn. Researching this may help in your project.
