Using the roller rotary does must you change the steps per rotation with each different size cup? My roller diameter is set correctly, and I have confirmed the correct steps per rotation for the 88mm cup. But once you change to a 100mm tumbler it no longer does a full rotation. I have watched several videos and cannot seem to find my mistake in the process.
in the Rotary Setup you should be changing your Object Diameter and as long as nothing else has changed and there’s no slipping that should do the trick.
