I have a Roly Lasermatic 2 machine, it has been a great machine but I was thinking of upgrading the laser wattage. I now see that the company has gone out of business. Does anyone know if there are other laser models that could be adapted.
Roly only has a 10W laser available for $135.
Rolyautomation parts.
Unfortunately their website show all lasers sold out along with about 99% of the other parts.
More power likely means going fron 12v to 24v. A 20w laser will not be a simple drop-in. If it is not the manufactures brand, an adaptor plate might be needed too. then the greater mass of the laser module may be more than the current frame can handle.
Have you compared the cost of a more powerful module to the cost of a new machine, already designed for the higher power?
Yes, that’s what I’m kind of doing now. The Lasermatic has been a great tool to learn on but appears to be a boat anchor if it breaks now.
Aaaaand greater size, requiring tweaks to the maximum travel / homing positions / whatever. ![]()
See? The list just keeps getting longer and longer…
I may be biased, but I have 3 Sculpfun machines now.
I bought a pair of 500mw machines off Amazon for <$80 each. The controller and power supply was only 12V, luckily the laser was also, however the NEJE40630 draws 3 amps.
I kept the left one original, the right I added the 5W NEJE. Had to make a mount out of pair of acrylic pieces with locking pieces.
Works well but a bit difficult to focus. On the right image you can see the conversion board, it could be run directly into the machine, but I never got around that that.
You can do it, just have to plan for it.
Good luck.
