I have a cloud ray roller rotary and have set the steps per revolution. When I test this by engraving a line around the entire part the two ends line up almost perfectly. The problem I am having is when I engrave a smaller image the resulting image is not the correct size.
When I engrave a 12.47 inch line it is almost perfect.
When I engrave a .5 inch line it is .08 small.
When I engrave a 2.8 inch line it is .6 small.
This seams backwards to me, I could understand if I used a small length to “calibrate” my length that even a small deviation would result in a large difference on eve scaled up, however at the longer length I am almost perfect, just a few thousands long.
Am I missing something very simple?
Thank you
Andy
