jkwilborn
(Jack Wilborn)
2
You or it doesn’t need to know that… If your steps/rotation (mm/rotation) are correct the software will compute surface speed…
Assuming a chuck type rotary, a wheel rotary doesn’t require any object diameter…
Try this thread and see if it helps you out… I’m not a wizard with these…
Good luck
