i set rotary up 100 times ive tried on off and every way possible the only way i can get rotary to turn one revolution is to adjust the diameter the steps per rev makes zero difference. i have a chinese laser and chuck rotary the stepper motors on both are the same i unplug Y and plug in Rotary. if i try to move laser 10mm it moves about 3.5 times that on y axis bit x axis is correct
Did you enable the rotary in LightBurn and set the rotary steps in the LightBurn rotary setup menu or are you playing with the X-Y menu?
