Do we know when the patch to fix the rotary issues is going to be coming. It has been a few months with resetting my machine everytime a mug is fixed.
Thanks
Dave
Thanks
Dave
Hi David,
Could you go into more detail with the exact issue you’re experiencing?
We do have some rotary fixes arriving in the forthcoming 1.2.02 release, but I don’t have an estimate to when that release will be.
the laser goes back to 0 0 instead of where you placed the origin.
Currently the rotary enable mode does not convert the Y move button to the new steps per mm. That is to say if you request a Y move of 10mm the machine moves based on the $101 settings and not the rotary “translated” steps per mm.
I have not tested this if the rotary axis is set to Z or A. Well, second edit… there is no move button for an A axis so I could not test that.
-Shane
Oh, cool I learned something! Thanks.
It was fine and worked great until you added the fiber update. Ever since then when doing rotary it goes back to 0,0
