Rotary Mirror Output
Hi. Now in the latest update when i have letters in mirror mode (rotary setup), in the preview mode, they dont came out at all
Are you saying this worked properly before the upgrade from what to 1.0.0.6?
I made some burns with this setting and was ok. I notice something else. I used to burn an svg image and letters. Now if i select all and merge,. Then is ok. If is separate, the name (letters) do not show to the preview
Do you have them enabled in the layer to output and show?
It would be helpful to drop the .lbrn2 file on the reply window and it will upload it for us to examine.
I’m sill not clear on the upgrade and the resulting issue.
NefeliAnimals.lbrn (101.6 KB)
I have rotary enable and mirror enable. When preview this, you cant see the name
Which ‘Start From’ setting are you using? If you’re in ‘Absolute Coords’ mode, the rotary flip tends to move stuff outside the working area of the laser. Absolute Coords mode generally doesn’t work for rotary anyway - User origin or Current Position are preferred.
I set the job origin in the center/left for about everything I’ve done on my rotary.
Screenshot from 2021-12-13 10-41-19
This places the ‘center’ of the design at the center point of the mug or cup. Generally that has the manufacturers information or logo.
Put in rotary settings “mirror” and the text to normal reading and try again
