Rotary set up problem
I have an xtool D1 Pro 20w. I just obtained an xtool RA2 rotary. Hooked it all up and sent a test burn of an equilateral triangle of approx 18 mm. It burned an isosceles triangle (laying on it’s side) of approx. 20x40 mm. What setting needs changed?
Try changing steps per mm under rotary settings :slight_smile:
i don’t see heading labled steps .all I have is rotary Axis Y,Zand A (have tried all three) mm per rotation (set at 360) Object diameter (set at 72 which is the diameter of the tumbler) and Circumference (set at 157.08 which is slaved to the diameter input). Also I have rotary type selections of chuck and roller (chuck selected tried both)
Got it!! I adjusted the mm per rotation down to 120 and it came out perfect. TY
Youre very welcome
The test button in the rotary gui should rotate the drive wheel or the chuck one complete turn and back.
