I encountered an issue while mirroring to a rotary.
I opened a previously saved file with the rotary type selected as ‘chuck’, and ‘enable rotary’ and ‘mirror output to rotary’ already toggled on (these settings were set in the save file). Upon opening the file, if you click ‘Preview’ it will show the image un-mirrored. If you then go to ‘Rotary Setup’ you can see everything checked and toggled already. Doesn’t matter if you click ‘OK’ or “Cancel’, but after closing out the rotary setup window, if you then click 'Preview” it will show the image properly mirrored.
Is this normal? Even if the settings are already saved, its necessary to just open and close the rotary setup window in order for it to work? Any help is greatly appreciated. Thanks! (and yes I engraved something backwards before noticing this)
