The rotary setup is not staying enabled. after running the test, i get the following error message " Setting could not be restored to controller after test run." Even with the rotary setup no enabled, the file still engraves, just stretched out.
Error message is new to me … Lightburn is trying to write changes to the Ruida and it’s not working.
Do you have a lot of files on the machine?
If so, delete what you don’t need… The Ruida acts up when it’s memory fills up.
How are you connected USB or Ethernet?
