I have a chuck style rotary for my 30w Fiber and the latest version of LB. I have to mark a ring of stainless steel with exactly spaced 25 divisions around an OD for an adjustment collar (1.250" diameter OD) on a reamer stop. I have not managed to get my rotary to work very well in the past and was wondering if somebody could provide some basic set up parameters.
Draw a rectangle the dimensions of your cylinder. 1.25" x whatever your depth is. Draw a line along one end. Duplicate it and move the duplicate to the other end of your rectangle. Make sure both lines are snapping to the rectangle. I woud place the rectangle on a tool layer and hide it it this point. Select one of the lines and duplicate 24 times. (Ctrl + D) Select all 26 lines and use the distribute tool to space them evenly. Delete one of the end lines, because it would overlap at the seam.
Another method, makes perfect graduated dials and such, is repeat marking. You can even add variable text, works great. Not circumference dependent. Here is a write up I did on LMA
Rotational Repeat Marking with Variable Text
Setup screen for a rotary with 38400 microsteps per rotation. Should just match what you have in rotary setup.
Start with 50 graduations
Then add a longer tail and variable text every 5 graduations
Short video, about 2 minutes:
https://firearm-videos.sixguns.com/channel/Albroswift/video/40/win_20250105_11_33_05_pro
https://masters.lasereverything.net/posts/rotational-repeat-marking-with-variable-text
Here is the original thread:
Thanks all, appreciate the help
