Rotary Setup for pictures
My rotary images come out are thin and compressed.
5000 steps per rotation is what the default setting is, IIRC, I would think your microstep driver is probably set higher, like 6400, 12800… when you hit test I’d bet it doesn’t turn a full rotation. If it doesn’t, try something higher.
Thanks, that worked. Now it’s inverted as in the picture.
Thanks, that worked It is 12800. Now it’s inverted as in the picture.
Try this
Thanks, that did it
The most simple way, is to turn your rotary 180 degrees.
On my co2, it’s motor was on an undesirable side so I swapped the phases on the motor.
:grinning_cat:
Simpler then toggling the reverse switch in the setup window? :laughing:
Just a hardware change … you’re probably correct, I was out at my machine when it turned up first time…
:grinning_cat:
Galvos dumb it down to the point it’s hard to remember it really is a hardware change. I just look for a toggle button… If it’s on, turn it off. If it’s off, turn it on. :rofl: :rofl: :rofl:
I have always thought, lets eliminate the hardware, that’s generally pretty easy. Since I’ve worked around hardware mostly, I tend to think in that direction first.
Just me, I guess :man_shrugging:
:grinning_cat:
