Rotary test is moving the wrong axis
So I have a Thunder Laser and the rotary accessory with the 7 pin connector.
When I use the rotate buttons in the move window the rotary accessory rotates as expected. When I use the rotary setup test it move the y axis instead of the selected a axis.
So lightburn an control the a axis as seen by the rotate buttons but the test just moves the laser around and ignores the a axis completely. I have wasted hours on this. What is the magic step I am missing?
There were a few users here that discovered changes to the Rotary controller when firmware was updated. Which Ruida controller are you using?
