Rotary tool is not working with Lightburn and my xtool d1
It works fine with laserbox but not with Lightburn. I’ve gone into the rotary tool to set it up but still nothing. I can engrave and cut with lightburn but I can’t get the RA2 or the old rotary working with lightburn. Any suggestions?
I’d like to confirm a few running details first. Which Laserbox version is working for you and which version of LightBurn are you working with?
Which firmware version is displayed in the LightBurn Console window when the xTool D1 connects?
How far did you get through the setup? At what point did you get stuck?
The version of Lightburn is 1.2.00 and Laserbox is Version 1.3.0 (1.3.0). I can use lightburn for everything except the Rotary 2. if I set the Units/Grid to any setting better for diode. It frames a tall thin area. Nothing close to what I have set and if I set it to anything on the left, and I frame, it turns completely around. Way over what I am trying to frame. It simply just does not work for that.
