Rotary will not frame
Earlier when I updated to the lates software, all my functions were reversed. and would not home. That has been fixed. MY issue now is that in rotary I cannot get it frame correctly. It would spin about 4-5 times in each direction. i assumed that it needed recalibration. I have been using Chat GPT to help, but to no avail unsuccessful. Close but not right. This started in early December. Had to walk away for a while and do other things. Now I am back and need to get it fixed.
Robert D
First go to the Rotary Setup screen and enter a value for the mm per rotation. Then hit the test button. The rotary should rotate in one direction then the other direction and end up exactly where it started. Once that is done and correct set the circumference of the object you are using.
Set Lightburn for “current position” and manually move the laser head where you want to do the design and hit frame.
