Rotating Image 90 Degrees causes image preview to show garbage
When rotating an image by 90 degrees the preview gets all garbled. Is this a software error?
Let me know if there is anything I can do to fix.
Thank you!
Thank you for reporting this.
I imported an image,
Rotated the image 90 degrees,
Then Selected Adjust image and the aspect ratio was messed up in the live preview.
I will get this to the dev team right away.
Preview window renders correctly - it’s the Adjust Image - live preview that is amiss.
@anon334 - I have it on good authority that this has been fixed for 1.4.01. Thank you again for reporting this.
