Can’t get my Ruida controller to link to Lightburn wirelessly. I’ve read 10 other posts on this issue as well as the official Lightburn FAQ on the topic- still stuck. USB works fine. My router IP is 192.168.0.1, my laptop phone and other devices all show up in DHCP reservation as 192.168.0.1,2,3,4,5, etc. I’ve assigned the laser 192.168.0.200 on the Ruida controller. I have restarted all devices. I’ve tried a number of different IP assignments for the controller. I have pinged the laser with network utility (macOS) and got “request time out”, “host is down”. After setting up the device manually in Lightburn and assigning the above IP, i get “no device found”, and “File transfer failed”. The network icon on the controller shows a red mark.
What is your 6445G plugged into? Do you have a WIFI unit / adapter on the laser itself? The controller does not do WIFI on its own, so you’ll either need a WIFI adapter that the controller is connected to, or you’ll have to use a network cable.
