Has anyone experienced this?
Send a file to my Ruida controller and start the burn from the controller, then if I start working on a different file in Light burn It sends something to the Ruida controller and it jumps over in the X-direction about 90mm and continues with the burn.
If I disconnect the printer cable it runs the file just fine.
It has just started doing this with Rev. 06. It’s a pain as I’ve had to throw out several projects.
If it’s a USB cable, the problem sounds very much like typical USB communications noise.
If it’s an Ethernet cable, then something else is afoot.
Which connection do you use?
USB Through an HP laptop docking hub. It’s odd that it just started doing this after I upgraded to .06
Mysteries and coincidences abound in the world today …
Thanks for your help on this issue, my Ruida is now doing a random strange hiccup so I’m going to have to order another one. I sure wish they had a more robust controller.
