The display show only the Right half of the drawing, from RD cam it shows normally. Have no clue what is wrong. Attached the pictures of the drawing in the software and a picture of the display.
The display looks like it’s showing you what’s currently running because you’re only half through the job. If it’s not running, then you’ll see the whole thing.
This is happening if I run the job on Laser head 2 (2head machine)
With Head 1 it shows everything OK, I think I have this issue until I set up the second head offset in other settings.
and also after job finishes it shows always only this part of workspace,
if I have a job somewhere outside this window it works but the display is empty
