Ruida is slow to fire!
Hi, need some help!
just setting up a new ruida but having trouble getting it to fire on time! (i think). very new to all this but it looks like laser power supply is not firing quickly enough !
is there anyone out there who knows if there are any settings to fix this?
Thanks
Make sure that’s not a mechanical slop issue first - Unless you’re moving really fast those lines should be nowhere near that far apart. Check belt tension, couplers, and pinions to make sure everything is snug.
Once you’ve done that and gotten it as close as possible mechanically, then look at the software side here: https://github.com/LightBurnSoftware/Documentation/blob/master/ScanningOffsetAdjustment.md
Thank you so much… just spent the day checking everything! i’ll give it a go tomorrow !
