Just have a wierd one where my laser isnt firing. I have a “red black” ruida 6442 Chinese cutter.
I’ve Doing some testing and if head is all the way to right it works, approx a 50mm range. Move a bit left it goes off. There is an audible click when moved and a light on psu goes off. Any thoughts? The Y axis is perfectly fine. I Only have homing limit switches and I have tried disconnecting them but it makes not difference.
They are set as they always have been @ 400mm. That was the first thing I tried, by increase it to 1000mm (600mm more than that machine) to see if that made a difference but it didn’t
yep so I went to diagnoses, First time, none were lit… Then i mucked around and went to where it was off, then it shows XY limit lit. Then I moved back and forth and they werent. Its a bit intermittent there. Definteily I think its some kind of “limit” issue, but Not sure what.
Do you know if theres a way to turn off any software limit?
They are the Clicky snap limits…nothign odd I can see, I testing the limit switch with a multi meter and they “seem” to be working ok and don’t fire unless clicked.
Seems hard to troubleshoot.If its a replacement part job I dont know what to replace, whether its the controller or the PSU
The “easy way” to test them would be to short the wire on the X limit on the machine. Limit switches are usually “normally closed”, so if you short them, they can’t be interrupted. That would eliminate noise from the switch. It’ll make homing a bugger though.
Ok I have it sorted. YAY it was the laser pointer that was causing it somehow… perhaps a cracked wire? not sure… now thats unplugged it all works… YAY. I dont really use the pointer much anyway tbh. although I should now with the new lighburn registration feature
It could be rubbing at some point in the drag chain, and when that point in the chain bends, it pulls the wires apart, and when it relaxes they touch again. A 5v direct short could cause power drain or weird ground loops or something. That’s very interesting that it showed up this way. That’s one for the ‘weird things I’ve seen’ category.
