RUIDA RDC 6442G with RD Works engraved, LIGHTBURN not
Good morning,
I have converted my gweike cloud to a Ruida controller, similar to omtech polar. First of all everything works well, with lightburn it positions and cuts perfectly, but doesn’t engrave, but he engraves with RD Works. So it seems to be a Lightburn theme. You can see that the laser tube is being activated, it is also drawing current, but no power seems to be arriving. It would be great if someone could help me.
Greetings from Germany
Uli
If there are spelling errors here, it’s the Google Translator’s fault :slight_smile:
Hat keiner eine Idee für mich ?
Does no one have an idea for me?
Well, I just woke up; I’ve never been able to type while asleep. :grin:
Perhaps the engraving speed is too fast for the available power, so that the beam does not damage the material. In some cases, the speed increase comes from a mistake in the units: an engraving at 500 mm/min is much slower than one at 500 mm/s.
You can help everyone help you by including screenshots of the cut settings and the design in LightBurn, along with photos of the results.
I assume you mean you added a Ruida console.
I would also make the same suggestion as @ednisley noted.
The controller seems to work fine, just the controlling software.
