Ruida RDLC320A Dual Laser
Hello
There is a Rudia RDLC320a controller. I would like to use the outputs of both lasers. The problem is this.
I’m using Lightburn version 0.9.14. in layer settings I can’t choose between lasers.
This option does not appear.
Tomi
At present, you must be connected to the machine for LightBurn to recognize that there are multiple heads and present the options for the second head.
Plugged in, of course. I turned on laser2 in the controller via Lightburn.
For some reason I had the 320 set as single output only. I’ve changed this for the next release.
Thanks for the quick response. Then I look forward to the next release.
