MuForum
(Damian Alexandr)
21
Hi @adammhaile.
Can you please answer a few questions about the “LightBurn Bridge” device?
- Can you tell me on which ports I need to send packets so that they reach the laser?
- Will it be enough for me to send the same packets, but instead of the UDP protocol, use the TCP protocol?
P.S. → I will be glad if you can answer my questions. Thanks in advance.
MuForum
(Damian Alexandr)
22
@jkwilborn - Thank you very much for your help.
You helped me a lot.
Can you please do one more thing.
I need you to run one command directly on this device “LightBurn Bridge”:
sudo netstat -tulpn | grep -i ‘LISTEN’
I need to know what other open ports are listening on this device.
MuForum
(Damian Alexandr)
23
Hi @adammhaile,
Can you please answer to my question.
“LightBurn Bridge” use TCP port 5005 instead of UDP ports 50200/40200.
- 0x4C + 2 bytes UDP packet length + UDP packet with checksum.
I need to know, what TCP port using instead of 50207/40207 UDP ports.
Thank you.
jkwilborn
(Jack Wilborn)
24
Didn’t get any values…
pi@lightburnbridge:~/mjpg-streamer/mjpg-streamer-experimental $ sudo netstat -tulpn | grep -i ‘LISTEN’
Without ‘grep’
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:5005 0.0.0.0:* LISTEN 447/python3
tcp 0 0 0.0.0.0:8080 0.0.0.0:* LISTEN 27480/mjpg_streamer
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 490/python3
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 455/sshd
tcp6 0 0 :::8080 :::* LISTEN 27480/mjpg_streamer
tcp6 0 0 :::22 :::* LISTEN 455/sshd
udp 0 0 0.0.0.0:51752 0.0.0.0:* 355/avahi-daemon: r
udp 0 0 0.0.0.0:68 0.0.0.0:* 549/dhclient
udp 0 0 0.0.0.0:5353 0.0.0.0:* 355/avahi-daemon: r
udp6 0 0 :::57359 :::* 355/avahi-daemon: r
udp6 0 0 :::5353 :::* 355/avahi-daemon: r
Sorry was snoozing…
