Anyone have this issue with their Ruida remote panel screen. It’s all fuzzy and unread but the control panel still functions.
I’ve changed nothing. Worked one day and not the next.
See attached image.
See attached image.
Check the plug/connections.
Thanks for the suggestion. I’ve removed the plugs and plugged back in with no luck. I’ve tried wiggling the cables but no change in screen. I’ve tried disassembling the panel, removing all cables down to the screen itself and plugged everything back in with no change.
I’m going to assume the panel itself is broken and I’ll need to re-order a panel but not the main controller.
That is unless someone else has some ideas.
Thanks
