Ok. So I’ve been engraving for a while and I’m having an issue with running files through my ruida that go totally haywire after 75-80% on the take of the file. Last file was 45mb and I’m pretty sure it’s supposed to handle 100mb. It’s so frustrating as it burns 2 minutes of engraving and then ruins the burn by going wacky. Is there a way around this? When I Send the file direct it takes it but the image comes out spotty. Please help!!?
All I do is engrave and if I can’t handle large files 90% of what I do doesn’t work. Thanks I’m advance
So. Maybe the file gets 80% sent to the machine and the laser will start to on each pass move larger than the .5mm spacing and also left and right out of line. I’ve had the laser smack into my weights to flatten my wood. I’m attaching a picture to view. This happens on larger files but about 1/4 of capacity. If I shrink the image in lightburn, I can burn a smaller sized piece but I can’t do anything of decent size right now.
