I have two galvo machines, one is a fiber 30W JPT and the other is a UV 5W JPT. As UV is now supported with LB I want to switch over but I can’t get it running. The UV was running once but now, all I get is a “connection failed” error. What am I missing?
hi! I have the same machines and had the same problem. I solved the problem like this. First I turn on Lightburn and select uv and only then turn on the machine itself. Then everything connects normally
