Hello together
I have a problem.
I would like to laser several parts at once, the distance between the laser head and the material is 8mm. There are wooden strips attached to the parts that are 12mm high. How can I tell LightBurn that it must follow a defined path so that it does not drive into the wooden strip(s) when moving to the next part? Is there a function? Thanks
