Save File AFTER Removing Overlapping Lines?
Is there a way to save a project after it’s removed overlapping lines and/or after generating the offset fill?
Thanks!
Edit > Convert to Cut
What does this do for you? Still learning.
It runs all the processing it would normally do when creating the job for the laser, then turns the result into a normal shape in LightBurn. It’s mostly for internal use, debugging image dithering / alignment, and so on, but it’s occasionally handy, so I left it in for others to be able to use. Not something you’d normally need.
Cool, thanks!
