Save Support Setting to job rather than globally
Hi,
I am running LB 1.6.03 and using an Emblaser 2. Is there any way to save the Support setting with the job rather than globally?
At the moment when you are switching between jobs that use or don’t use the support, you must always remember to adjust the setting. And if I coming from a job that does not use the support to one that uses it and forget to set it, the head can plunge into the workpiece at the start of the job.
All other settings - speed, power, material height are saved per job; why not the support setting?
Thanks
Steve
Can you clarify what you mean by the “support setting”?
I have not seen that option before, it’s possible that it’s specific to the Emblaser. Hopefully someone with more specific knowledge on this can chime in.
Yes, I believe that it is specific to the Emblaser.
Thanks
