when I save a "calibration"file ie focus beam.lbrn…when I open it the work origin and “pass through” options are the same as My last piece of work…when I saved the file pass through is unchecked and work origin is centre…
Work origin isn’t saved with the file (though I’m going to change that relatively soon). Pass Through should absolutely be saved - I’ll look to make sure it is.
You were correct - This is fixed for the pending release.
