Is this possible? I was going to send a file to a friend in reference to a discussion and was not able to save a G-Code file to reference in my message.
It appears that the machine, in my case a K40 with the SBASE MKS v1.3 controller, must be online to save the file. Is this correct or am I missing something?
LightBurn does not require you to be connected to the internet for any reason beyond license activation and this is not even required if you register and complete the ‘Request Offline Activation’ feature.
You will need to define a ‘Devices’ profile as the code generated will be specific to the firmware of the intended output laser device.
What happens when you try to select the ‘Save GCode’ button?
EDIT: Sorry, I misread and thought you were asking about being “online”.
Please post a screenshot of your entire LightBurn screen including showing the ‘Laser’ window.
It appears the ‘Beginner Mode’ has been turned ON (green). This changes the UI to remove more advanced features thus helping our new users. Going to the ‘Settings’ window and setting this to OFF (dark-red) will bring back the ‘Save GCode’ button in the ‘Laser’ window. Could this be the issue?
