Scanning Offset Adjustment
When setting up the Scanning Offset settings. Is it better have more speeds set up in there? If you have one is it smart enough to calculate others? Like if I have 200 mm/s with say 0.5mm offset and I do an image with 300 mm/s will it increase the offset itself or how does that work?
You need at least two for any others to be extrapolated. Start with two measured speeds, and if you need more after that then add them.
Thank you sir! Will do
