Scanning offset confusion
I was engraving image with thick grass on it so it were a lot of lines from grass and i saw that my grass is getting blurry image. I increased my scanning offset to +0.25 and it was now sharp image. But later i tested another engraving on 0.0 it was also sharp image and then i engraved again grass on 0.0 it was sharp and when i increased again on 0.25mm it was also sharp without any changes. I am now more confused than before
Not sure how you arrived at this, but for Lightburn to properly use this you need to set the offset a several different seeds and Lightburn will extrapolate the gaps. You can’t get accurate results with only one setting.
