screen size in windows operating system
if you have your MS windows settings to “scale greater than 100%” say 150%" it confuses light burn
I have this display running 125% without an issue.
What is it you have a problem with?
That would depend on your screen resolution. If you are using a low res screen like 1366 X 768 you may need to also adjust your font size and or toolbar icon size in your settings.
You can also try disabling high DPI scaling.
i was using 1920x1080 but i was having trouble with the LightBurn UI, but i had the MS windows display “scale” set at 150%, i changed it to 100% and my problems with LightBurn UI ( and MillMage UI) went away, so problem solved. i was posting for other people having same problem, seem to be alot of ppl with that very issue.
