SCULPFUN 20W – X-axis suddenly shifts to the right during engraving
Hi everyone,
I’m having a strange problem with my SCULPFUN 20W diode laser engraver using LightBurn.
The machine was working perfectly before I left it unused for about 10 days. I haven’t changed any settings.
Now, the engraving starts correctly, but after some time the image suddenly shifts several millimetres to the right. The displacement can get worse during subsequent attempts.
I’ve run the same image three times:
  • First attempt: misaligned.
  • Second attempt: almost perfect, but suddenly shifted near the end.
  • Third attempt: severely misaligned.
The X-axis seems to move normally, without obvious jerking or unusual noise.
I’ve checked the belts and tightened three screws on a metal wheel, but the problem remains unclear. I haven’t identified the exact cause yet.
I’m using LightBurn, and the device is configured as GRBL, although I haven’t confirmed the exact controller board or firmware version.
Could this be caused by a slipping pulley, lost steps, a faulty stepper motor or driver, or something else?
What diagnostic tests would you recommend to identify the cause?
Thank you for your help!
Usually a mechanical issue, go through the steps here: Guide to mechanical adjustments and maintenance
A good rule of thumb: When something changes and you haven’t changed anything, it’s a mechanical problem, so don’t change the settings.
However, if you just updated LightBurn, that can introduce some jank; let us know if that’s the case.
This suggests there are many loose things, not just a few screws, so play attention to all the items in @misken’s list.
Some previous discussions show hiding places:
Thank you for the detailed explanation! This is really helpful.
I just want to clarify one point: when you say “hold the shaft and rock the collar/pulley back and forth,” how exactly should I hold the shaft? Do you mean holding the motor shaft itself with pliers, or simply keeping it from rotating while gently moving the pulley with an Allen key?
I want to make sure I understand the procedure correctly before trying it, so I don’t damage anything.
Thanks again for your help!
With the pulley setscrew(s) loose, it should slide easily on the shaft toward / away from the motor. With the pulley loose, you can (probably) skootch it around to center the screw (or one of two screws) on the flat without having the shaft turn along with it. This requires taking the belt off, but you must do that anyway during the inspection.
If the pulley doesn’t slide easily, the shaft may be scarred due to not tightening the setscrew on the shaft’s flat and will require attention from a fine file to flatten the burr.
Using a (needle nose) pliers on the shaft is considered Bad Form, but (after you fix the burr situation) sometimes you gotta do what you gotta do. :grin:
