Sculpfun limit switch upgrade won't home to 0,0
My sculpfun when it homes says it is at x-382 y-382
I purchased a Sculpfun S6 pro. I upgraded the laser to a Sculpfun S30 10 watt and installed the Sculpfun X axis upgrade and also installed the Sculpfun limit switch upgrade. I flash the firmware for my motherboard (DLC v1.0).
When I homed the laser it said it was at x-382 y-382 so I put the command G10 L2 P1 X-382 Y-382 in the console window hit enter, it accepted the command.
every time I home the laser it still says it is at x-382 y-382 but when I have to move, say to x50 y50 it does move correctly to the right 50 and towards the back 50.
Is there a way to have it home to o,o?
Did you also set $10=0 so that the controller reports working position rather than machine position?
I think PY is right. $10 needs to be (un)set if you use it like this. You can also flash another firmware that gets rid of this requirement. For reference, check all settings here: Limit Switches - Diode Laser Wiki
Thank you setting $10 to 0 did the trick. Hopefully someday I will understand all the $ settings and how they affect the laser
