Sculpfun s30 pro max . jumping when engraving rotary for tumblers
Hello, I’m new I have sculpfun s30 pro max . I’m having trouble with it jumping when i use the rotary for tumblers. how do I fix it?
Which setup did you use? Which speeds? If you use a rotary, you need to drastically reduce speeds (I’d say 1500-2000mm/min maximum). Otherwise objects start to slip. Here are some guides:
If you’re using a roller rotary, this is common. The root cause is acceleration to the intended speed. I’d suggest lowering the rotary axes acceleration values… time/distance to top speed will be affected as will overscan.
