Sculpfun S30 will not start project
my equipment and software have worked fine in the past. Now the software will frame the project on my material but when I press start the laser simply moves slightly then the power switch dems and the project will not start.
This could be several things, but the most likely is that the rocker power switch is going bad. With the power off, flip it back and forth several times. Then turn it on and see if that is a fix, If yes, it is only very temporary and the switch should get replaced.
Next would be the power supply, either it is going bad or the power connector on the controller board is defective (loose fit).
