Sculpfun s9 Mirrored Print out
I just got my sculpfun s9 setup with lightburn. Dont understand why it is printing mirrored to the Y Axis. Change Device Setting Origin, using the 4 options, computer screen follows the setting but its always mirror on the Y Axis. I need help please.
  1. Set your machine origin to bottom-left in Device Settings.
  2. At that point what you see on workspace should be how things burn. So if something is not oriented correctly then fix the orientation and test a burn.
Additionally, to PYs comment: if you use the arrow buttons in the move window, does the axis move correctly? Then it’s the origin setting as mentioned.
