I have a question about the air assistant.
Is it possible to implant a second command, for example M10?
The reason is, I want to work with engraving with a pressure of 0.5bar and with cutting with 1.5bar.
The whole should be switched via a pneumatic electrical valve on the mks sbase v1.3 board. The choice between M7 and M8 from the device settings also as an alternative to the cutting data …
It’s not possible at this time. I’ve seen this done by having the “off” position be engraving pressure, and the “on” position be cutting pressure - basically have two regulators on two parallel lines, and a solenoid on only the 2nd line (with higher pressure).
+1 here who would like to have a second “switch” as well.
Does Lightburn uses both commands M7 and M8? I just saw a switch in the settings where you can choose either M7 or M8 for AirAssist. Could it be done, that LB can use both commands simultaneous (like M7 for flood and M8 for AirAssist) and add another swith to the layers where one can choose what to switch on?
