I imported a DXF and autojoined the line to create paths. The program runs all of my fill and cut areas great, but the starting point for the cuts is in a terrible location that leaves an obvious tick mark in the material.
When I try to use the “select starting point” tool, the profile highlights (single profile not a group) but no nodes are showing to select as new starting points. When I use the same command on a Lightburn drawn profile, every node pops up and i can easily select a new one, but not on this imported file.
Is there some reason this imported DXF wont bring up nodes for selecting a starting point? They pop up in the node editor if i want to drag them around, just not on starting point.
