When I open a project, and try to frame it, I get a “running this frame might exceed the bounds of your machine”.
If I then hit preview, it shows objects outside the workspace, usually containing QR codes.
As a workaround, I move that object outside the workspace, hit the preview again, and only shows objects inside the workspace, and works fine.
I have found the setting for “ignore out of bounds Shapes” and it is on, so I turned it off, then back on to see if that helps, and it doesn’t.
Ami the only one with this issue…
